beachbreeze
#1 Posted : 12 years ago
beachbreeze
The right front burner cook top light stayed on for over 12 hours before going off. Burner works fine and light is off. Could this be caused by a spill or is something on the way out?
#2 Posted : 12 years ago
Parts for Jenn-Air JES9800AAW Range - AppliancePartsPros.com
See the attachment for the wiring diagram
As you can see the lights are controlled by the infinite switches so probably he one for that element has a problem.
A spill may have caused it. If you had a spill and the unit is now working correctly I would not worry about it.
File Attachment(s):
JES9800.pdf (824kb) downloaded 5 time(s).
