Hi, my washer not working in the spin cycle. it washes and agitates, it even drains most of the water. but it doesnt spin the water out of the clothes. I did some research and thought it was the clutch, so i replaced that. Not the problem. help!!
Groups: Expert
What is the model number? Assuming it is a Whirlpool direct drive, run it in spin mode with the cabinet off and lid switch bypassed. Observe the clutch hub while in spin mode. After it drains, the motor should pause for a few seconds and then start again. When it starts again, is the clutch hub spinning? If so, either the clutch is slipping, there's a problem with the brake cam driver, basket drive or tub drive block. Where did you buy the clutch from? Eric
