karpat80
#1 Posted : Sunday, April 19, 2009 1:39:19 PM(UTC)
karpat80
I've never cleaned the filter in my Sears Kenmore Ultra-wash dishwasher Model Series 16770 which I purchased new in 1988. The manual gives no mention of a filter. The washer is starting to make a weird sound and I'm thinking that after all these years it may be caused by a clogged filter. Is there anyone out there that can direct me into how to clean the filter if there is one?
TIA
#2 Posted : Monday, April 20, 2009 11:45:53 AM(UTC)
In order to provide most accurate advice we need the complete model number of the dishwasher and more specific description on the problem.
karpat80
#3 Posted : Monday, April 20, 2009 1:57:59 PM(UTC)
karpat80
Gene the Model # is 665.1677580, this is a Kenmore Dishwasher. It is very hard to describe the sound it is making. It's a medium pitch whine as if it was straining somewhere. The upper spray arm is not bound up. I'm wondering if there could be a clog in some kind of a filter either one bringing water in or one letting dirty water out. Is the Grate below the upper spray arm the only filter that this system has?
#4 Posted : Wednesday, April 22, 2009 10:26:49 AM(UTC)
Sorry for the delay. The first thing I would do is remove the pump outlet (#14 on the diagram) and check for a foreign objects inside.
Remove the wash impeller and the separator assembly (#9) and check the chopper (#19) and its spring.
karpat80
#5 Posted : Wednesday, April 22, 2009 1:03:17 PM(UTC)
karpat80
Thanks for the insight, it will be a weekend project.
#6 Posted : Wednesday, April 22, 2009 1:16:14 PM(UTC)
karpat80
#7 Posted : Sunday, May 3, 2009 11:45:18 PM(UTC)
karpat80
Good morning Gene:
I did all you suggesed but everything looked fine. I went out and purchased a new Bosch dishwasher this weekend and just completed the installation Sunday night. Have not had a chance to run it yet but I've heard good things about Bosch, time will. Once again thanks for your help.
#8 Posted : Monday, May 4, 2009 8:59:57 PM(UTC)
You are welcome. You bought the right dishwasher.
Guest (6)
