jonathanlandrum
#1 Posted : Saturday, March 30, 2013 8:21:55 AM(UTC)
jonathanlandrum
I searched the archives but couldn't find my same symptoms.
Unit had no heat, and I replaced upper thermostat and heating element after testing them. New element had 2 prongs instead of 3 prongs and lower thermostat doesn't have the same connections either.
I installed them according the instructions that came with the thermostat kit but it trips the breaker immediately when turned on -- heat or no heat. If I unplug the heating element and lower thermostat, it runs without tripping the breaker. I assume I've miss wired something.
Any ideas? Thanks.
Jonathan
jonathanlandrum
#2 Posted : Monday, April 1, 2013 2:14:24 PM(UTC)
jonathanlandrum
Repair guy came today, replaced lower thermostat, said things were hooked up correctly and still tripped breaker. He suggested I check the breaker and house wiring and that if they were ok, that it likely wasn't worth him trying to track down a short on the dryer.
Checked breaker: ok. Checked plug and I'm getting 255v out of it.
Any suggestions on where/how to track down a short?
Thanks.
Jonathan
jonathanlandrum
#3 Posted : Monday, April 1, 2013 2:20:11 PM(UTC)
jonathanlandrum
Getting 255v to unit. Not sure where to go from there.
jonathanlandrum
#4 Posted : Tuesday, April 2, 2013 5:42:32 PM(UTC)
jonathanlandrum
Borrowed a dryer from a friend and it all works fine. Guess I have a short somewhere. Any suggestion on tracking it down or junk it?
