I have an electric GE commercial dryer model# dncd450eaowc. I took the motor off to clean it because it was totally clogged with lint. My problem is that when I put the motor back on I realized I dont know where the wires go back on the motor. There is numbers on the motor terminal block. I just don't know what color wire goes to which number on the terminal block. Please help! I have disrupted my living situation by holding up the laundry.
THIS FORUM IS DEAD!!!!!!! |
Please take no offense Denman. But the wiring diagram for the ge dryer model# dncd450eaowc, motor was accessable through appliancepartspros. I know this because I called the contact number on the website, and they found me the diagram. It did take awhile but they did not give up. At least next time we will both know.
