Originally Posted by: jesus freak  ...In can turn the transmission pulley both ways...
...If I have the machine running when it is supposed to agitate, I cannot turn the transmission... So can you turn the transmission pulley CW or you can not? I'm a bit confused. Gene.
I can turn it both ways when it is off. I can of turn it by hand in the agitate mode.
With the belt on or off?
With the belt on and off. Both.
If you can not turn the transmission pulley then the transmission has to be replaced. It comes with the tub bearing and the tub seal kit. - The transmission Part number: 6-2097790
I can turn the pulley when the machine is off.
Originally Posted by: jesus freak  I can turn the pulley when the machine is off. I really don't understand what do you mean when you said "machine off or machine on". It does not matter in what position is the timer. The most important is if the drive belt is on or off. I can not see your washer. My diagnosis based on the information you provided and if it's not clear then there is not much what I can do. Gene.
The pulley turns both ways, whether the belts are on or off.
