rudyrudy
#1 Posted : Wednesday, March 27, 2013 1:47:53 PM(UTC)
rudyrudy
Anyone have instructions for removing the cabinet this washer has a welded cabinet all the way around, so removal seems complicated. Need to see where the leak is coming from (somewhere under the Tub but above the Tub platform.
Thanks for any assistance
Simon / APP Team
#2 Posted : Wednesday, March 27, 2013 4:32:11 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You can't remove the cabinet from this one. Remove the panel from the back of the washer at the bottom two 5/16 screws and observe the leak.
Also, raise the top by opening two clips in front.
Most likely it's a bad center post gasket, but with this old washer it could be corrosion too.
Here are the breakdown diagrams and 01-Tub and Basket , Lit / Optional parts for Whirlpool LDA7600W0 - AppliancePartsPros.com
Post the results.
Simon.
rudyrudy
#3 Posted : Wednesday, March 27, 2013 9:19:31 PM(UTC)
rudyrudy
Hi Simon, thanks, I can't see the exact leak location from the panel in the back or the top, but it looks like the center post gasket is a good bet. I can't read the part number for the center post gasket, can you reply with the part number? Thanks
Simon / APP Team
#4 Posted : Thursday, March 28, 2013 11:07:34 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I see what you mean.
Part number: AP3132853
Good luck. It's a big job.
Simon.
rudyrudy
#5 Posted : Thursday, March 28, 2013 11:12:22 AM(UTC)
rudyrudy
Hi Simon,
Thanks, I saw the video yesterday, can you also tell me the specifications for that "sprocket wrench" that I would need, considering that my washer is older than the one in the video? Thanks, DR
Simon / APP Team
#6 Posted : Thursday, March 28, 2013 11:15:38 AM(UTC)
Simon / APP Team
Groups: APP Team
Use the same spanner wrench.
Simon.
rudyrudy
#7 Posted : Thursday, March 28, 2013 11:26:04 AM(UTC)
rudyrudy
Simon.
Simon, Sorry, What size is the spanner wrench?
Simon / APP Team
#8 Posted : Thursday, March 28, 2013 10:40:26 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Here is the spanner wrench you need Part number: AP4503397
Simon.
