CroisanMountain
#1 Posted : Saturday, December 8, 2007 9:26:12 AM(UTC)
CroisanMountain
Rank:: Member
On Thanksgiving morning the radiant top and oven were working. At the end of Breakfast they quit. The clock, oven settng temp, etc. display still works. I reset the circuit breaker. When I turn on the element, it immediately clicks and the light on the panel flashes. The oven shows all signs of working except that it doesn't heat anything either.
I had the control panel replaced 4 years ago with the improved Sanyo model.
UPDATE===============
It turns out the circuit breaker itself failed. It was a Murray 40/30 quad.
I replaced that. (hard to find) But I still have a problem. The radiant element on the left side actually has 3 elements in it. A round front, a bridge element and a round back element. The rear element is not working now. Everything else is fine. I would appreciate any advice on how to get that one working.
CroisanMountain
#2 Posted : Saturday, December 15, 2007 12:51:27 PM(UTC)
CroisanMountain
Rank:: Member
One element is not working. Any advice here?
Left Rear Radiant Element not working (Oven Repair (including Ranges and Cooktops))
by Tom2012 4/9/2012 11:18:19 PM(UTC)
