billeagertolearn70
#1 Posted : Thursday, March 21, 2013 1:06:07 PM(UTC)
billeagertolearn70
AR microwave exhibiting symptoms of bad diode-no heat and humming noise. How do I get to the diode and how to replace. Awaiting a reply.:confused:
#2 Posted : Thursday, March 21, 2013 4:29:30 PM(UTC)
hello,
You have to remove the microwave from the wall. Remove the outer case to gain access to the HV diode. Discharge the capacitor by short-circuit the connection of the capacitor against the chassis with the use of an insulated screwdriver.
- The HV diode Part number: 5304467670
