TERMINAL
#1 Posted : Wednesday, March 20, 2013 11:14:34 AM(UTC)
TERMINAL
:confused:amana ice maker cycles but just fills with a little water also water on door used to work all the time now just when it wants to usually after an ice cycle i now fill maker by hand. i also replaced maker with another identical one but was used and worker
rickgburton
#2 Posted : Thursday, March 21, 2013 11:45:16 AM(UTC)
rickgburton
Groups: Expert
You could have a problem with the water valve behind the machine. To check the valve, disconnect the two water lines, ice maker and water dispenser lines. Disconnect the two wire connectors. Use a cheater cord to energize each coil with 120 VAC (hold it over a pail). See if the valve is working correctly
Amana Ice Maker (Refrigerator & Freezer Repair)
by ddurham 12/12/2014 11:11:07 AM(UTC)
Amana Ice Maker Funnel Freezing (Refrigerator & Freezer Repair)
by MiniDrivr 12/16/2011 1:41:11 PM(UTC)
Amana Ice Maker not filling with water (Refrigerator & Freezer Repair)
by dlstorch 5/6/2011 8:20:07 AM(UTC)
Amana ice maker not working right (Refrigerator & Freezer Repair)
by colbran 1/23/2011 9:02:45 AM(UTC)
Amana Ice Maker Stopped Working (Refrigerator & Freezer Repair)
by smaggard 9/27/2010 1:40:00 PM(UTC)
Amana Ice Maker Water Supply (Refrigerator & Freezer Repair)
by grouper 8/6/2010 1:35:58 PM(UTC)
Amana Ice Maker quit working (Refrigerator & Freezer Repair)
by modelships 5/9/2010 10:41:03 AM(UTC)
by JDGnut 12/13/2009 10:33:26 AM(UTC)
Amana Ice maker water valve (Refrigerator & Freezer Repair)
by muckamoo2 9/5/2009 6:26:46 AM(UTC)
Amana Ice Maker Makes Ice Does Not Dispense Ice (Refrigerator & Freezer Repair)
by ARS2664AC 5/9/2009 11:47:56 PM(UTC)
Amana ice maker replacement fill tube (Refrigerator & Freezer Repair)
by billwh 3/11/2009 12:38:06 PM(UTC)
Amana Ice Maker (Dishwasher Repair)
by tbonecanoes 3/9/2009 10:16:31 AM(UTC)
Amana ice maker not producing enough ice (Refrigerator & Freezer Repair)
by Jmsaufan 7/17/2008 8:44:51 AM(UTC)
amana ice maker (Refrigerator & Freezer Repair)
by ronaldm48 7/15/2008 4:01:03 PM(UTC)
by csaam 4/25/2008 3:19:25 PM(UTC)
