Jef_R
#1 Posted : 12 years ago
Jef_R
Hello everyone,
With the help of Gene, and others, I found out that my clutch was bad and i had to order another one. I just installed the new clutch and did a quick wash, without any clothes, and about 20 minutes into it I got the uc code again. I opened the lid and there wasn't any residual water in it, so I hit the start button again and it finished.
All the while, it has made some sounds that I have never heard before, pretty much during most of the cycle. So I'm figuring that I must of installed it incorrectly. Any ideas or suggestions would be greatly appreciated.
Thank you in advance.
Jef
Jef_R
#2 Posted : 12 years ago
Jef_R
Just started another quick wash with clothes and at about the 25 minute mark it seems to stop. it sounds like it's trying to rev up, almost like a airplane engine does, then revs right back down. It does this repeatedly. Just wanted to share this incase it help diagnose the problem.
Thanks again.
Jef
#3 Posted : 12 years ago
Hi Jeff,
Here is the very important part of the clutch installation instructions: "When reinstalling, properly seat Pulley with a 1/16-1/8" gap between the Pulley face and shaft end. On reinstallation, tighten Pulley Bolt to 96 inch pounds."
Did you do it?
Jef_R
#4 Posted : 12 years ago
Jef_R
Gene,
Thanks for the info. I had thought I did but apparently did not. I re-installed it again and it's running perfect. Thanks for all of your help. I really appreciated it.
Jef
#5 Posted : 12 years ago
You are welcome Jef. I'm glad it's up and running.
