Ivis
#1 Posted : Sunday, March 17, 2013 4:36:02 PM(UTC)
Ivis
When gets to rinse cycle, stops . Letters F H flashed . Help needed
#2 Posted : Monday, March 18, 2013 2:51:03 PM(UTC)
What is the complete model number of the washer?
Ivis
#3 Posted : Monday, March 18, 2013 2:56:52 PM(UTC)
Ivis
Where can I found the model number?
#4 Posted : Monday, March 18, 2013 4:46:18 PM(UTC)
Usually it's on the door frame.
Ivis
#5 Posted : Monday, March 18, 2013 4:54:16 PM(UTC)
Ivis
Model # Ghw9150pwo
#6 Posted : Monday, March 18, 2013 7:40:53 PM(UTC)
Remove the bottom access panel and clean the pump filter.
Check the pressure switch as described in the attached file.
Here are the breakdown diagrams and Parts for Whirlpool GHW9150PW0 Washer - AppliancePartsPros.com
File Attachment(s):
Testing pressure switch.doc (334kb) downloaded 3 time(s).
