SJBB
#1 Posted : Wednesday, July 20, 2011 6:29:09 PM(UTC)
SJBB
Dishes were cloudy and unclean.
changed detergents
called repairman
cleaned caked on soap/vinegar
The dishwasher will run the whole cycle with soapy water(I DID NOT put in soap). Is the valve not shutting off? Can you give me some things to check?
Do I need to get another washer or repairman?
clairresse
#2 Posted : Saturday, March 16, 2013 8:04:29 AM(UTC)
clairresse
the problem is not the soap and vinegar will do nothing. i have tried all these things for 2 months. i read that rinse aide leaking into the tub will cause suds so to check that dispenser and have it fixed if necessary. i plan to try that.
i also read several times that it is because phosphates are no longer in the detergents and you have to use finish powerball tabs. this might make sense because, for many of us, it is not most of the commontly mentioned problems . i have been experimenting.
