AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Bosch SHE68M06UC/50 Circulation pump replacing help
Hi, I really need help... I have a Bosch SHE68M06UC/50 dishwasher. I ordered the wrong circulation pump but learned from your CS that I should order# 665510. I have disassembled, removed the sump basin from base etc, to access the original pump. I did not "clamshell" as that looked very difficult to do on the right side.
How do I actually remove the existing pump? It is connected via some metal clamp that looks ratcheted on to one side, and the other side of cir pump that goes to the sump basin is very tight in the seal etc. Are there replacement parts for those 2 connections in case I need them, break the originals, etc?
Will I have any water problems since I disassembled? I was following disassembly instructions from another repair parts website.
Any help would be greatly appreciated. I'd like to place replacement order for correct circ pump and any other needed parts (seals, etc). Also, if anyone has the actual service manual with service codes that would be helpful (I only found older model service manuals here)
Thank you very much! Sam
Hi Sam, You probably can reuse existing front pump what will save you time with the hose clamps. The instructions are attached to the post. Gene.
Thank you Gene! I appreciate the help.
Dishwasher Repair
