matty0019
#1 Posted : Friday, March 15, 2013 10:22:28 AM(UTC)
matty0019
I received the replacement clock (control board) from appliancepartspro.com and have a question regarding installing it. My question pertains to the black jumper wire. Step #8 says if the jumper wire has a piggy back terminal (which mine does), the terminal needs to be removed. Step #10 says to crimp the 2 wires to the terminal included with the kit. Which 2 wires is it referring to? Do I simply cut the terminal (w/ piggy back) off of the jumper wire and crimp on the new connector (w/o piggy back). Then to reinstall do I plug the jumper wire onto the spade terminal labled "B*"?
Simon / APP Team
#2 Posted : Friday, March 15, 2013 1:17:16 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I don't have this instructions sheet. Please post it or the part of it you have question about.
Simon.
magic chef clock replacement (Oven Repair (including Ranges and Cooktops))
by edwebb 12/30/2010 7:11:03 AM(UTC)
Tappan Clock Replacement (Oven Repair (including Ranges and Cooktops))
by pfd225@roadrunner.com 6/13/2009 12:04:07 PM(UTC)
