nabours
#1 Posted : Wednesday, March 13, 2013 5:45:10 PM(UTC)
nabours
Our Kenmore dispenses crushed ice but not cubes. The solenoid will kick open but auger won't turn to push the cubes out. I'm thinking there may be trouble with the front door operator slide switch going from water/crushed/cubes. The auger turns when dispensing the crushed ice so I know the auger isn't stuck and works. How do I open up the door controls area. (front) I certainly don't want to break it. HELP!
#2 Posted : Thursday, March 14, 2013 3:11:35 PM(UTC)
Hello,
The control console can be removed by carefully inserting a small blade screwdriver at the lower edge of the console and gently prying downward at two places. Slide the bottom out and down.
- The dispenser control board Part number: WR55X130
nabours
#3 Posted : Friday, March 15, 2013 4:10:55 PM(UTC)
nabours
Crushed Yes, Cubes No, Repaired.
For what it's worth, I took apart the upper front panel where to circuit board is. Since the circuit board is small, I actually reflowed each solder connection with a little more solder, on the board, with a pencil soldering iron. I cleaned everything and put it all back together and Wa La! I now have cubes! I don't know if it was the solder job or just re-seating the two plugs, but it works and I'm a happy camper now with cubes generously flowing on demand and zero cost to repair. Thank you for your advice.:D
#4 Posted : Friday, March 15, 2013 4:24:28 PM(UTC)
You are welcome. I'm glad to hear you were able to fix it.
