jaja
#1 Posted : 16 years ago
jaja
I'm getting the error message 'LD' and the water is not draining.
sidfink43
#2 Posted : 16 years ago
sidfink43
LD is error code language for "long drain", meaning it is taking a long time for the washer to drain (but then you already know that)
You are going to have to open up the machine and clean/clear out the pump and water line. If you are lucky you just have an obstruction, if you are unlucky you will need a new pump.
Please post if you solve it, and if you need additional help please post the model number.
Good luck
Kenmore Elite Calypso Washer (Washer Repair)
by filosad 12 years ago
