Rank:: Member
Part # 12200039 Replacement Jenn Air Fan Switch - 2 Wires
Need too know what 2 wires should go to the replacement switch I just got. Currently there are 4 wires to the old switch. (I know I can only use either fan or light with new switch. What two would I use. Color wires are WHITE, BLUE, BROWN, RED
I have the same situation and just received my replacement switch with 2 connectors. Did you find out how to wire it to operate the fan?
I also have the same problem. I received my replacement part and I don't know how to wire it up. The old switch took 4 wires and the new one takes 2 wires.
Originally Posted by: lanham01 I have the same situation and just received my replacement switch with 2 connectors. Did you find out how to wire it to operate the fan? I also have the exact same problem. I have no idea how to wire the 2 wire fan switch from the 4 wires.
