Whirlpool refrigerator makes a tick tock sound from the R bottom area after I open the refrigerator door at a beat of 2 tics per second for about 3mintues, then the compressor turns on. The refrigerator cools normally. the noise does not occur every time the door is opened, but usually after door has been closed for while. the start relay seems does not rattle. any ideas on which part is needed? thank you.
I think the correct model is GD5SHAXMTOO narrowed down to condensor fan motor 833697 or overload relay 4387835, any ideas?
