fishbreath
#1 Posted : Tuesday, March 12, 2013 10:45:25 AM(UTC)
fishbreath
Hello
The above listed refrigerator has begun to have an issue with the refer compartment freezing, mostly in the lower boxes and towards the back. It also appears that there is a frost buildup at the back/lower vents inside the freezer. Additionally, the "Turbo" light is always lit. If I press the switch, I hear the fan come on. Push it again and it goes off, but the light always stays on. I have not defrosted the unit by shutting it off.
Suggestions?
Bill
#2 Posted : Tuesday, March 12, 2013 2:04:41 PM(UTC)
with a hair dryer, melt the ice and clear out the ice in the lower air returns. Use a dollar bill between the door frame and door gaskets in different places. If it is easy to pull out, the door gaskets are bad.
