bisland9
#1 Posted : Tuesday, March 12, 2013 6:20:47 AM(UTC)
bisland9
hi,
i hope someone can help me. i have a whirlpool refrigerator with a bottom freezer that keeps accumulating water, which turns into ice, and i have to break it up and remove. i first thought my ice trays were leaking but that is not the case. any ideas as to where this water is coming from. there is no water hooked up to the frig.
thank you in advance,
#2 Posted : Tuesday, March 12, 2013 2:40:02 PM(UTC)
There is a drain hole under the evaporator coils inside the freezer. This hole is clogged and frozen. Remove the rear panel in the freezer and defrost it using a hair dryer. Run some hot water though the drain using a turkey baster.
bisland9
#3 Posted : Thursday, March 14, 2013 3:59:03 AM(UTC)
bisland9
thanks gene, i do not know what evaporator coils look like but i will googe it...........thanks again..........if worse comes to worse i will just empty the frig and unplug it.
#4 Posted : Thursday, March 14, 2013 11:57:43 AM(UTC)
The evaporator coils are in the freezer behind the rear panel.
bisland9
#5 Posted : Monday, March 18, 2013 6:52:36 AM(UTC)
bisland9
thanks again
#6 Posted : Monday, March 18, 2013 12:14:52 PM(UTC)
nckrauel
#7 Posted : Friday, March 22, 2013 2:55:30 PM(UTC)
nckrauel
I have an identical problem (ice inside on bottom of freezer) with a Whilpool GB2FHDXWB09 bottom freezer. "I assume one cannot see the drain hole from inside the freezer". I was hoping to not have to pull the frig. out because I only have one arm and its not too strong (old)
Thank You for a Response
nck
bisland9
#8 Posted : Monday, March 25, 2013 4:07:02 AM(UTC)
bisland9
nck
i emptied out the frig and unplugged it............seems to work fine now......put a towel in the freezer to soak up the water
nckrauel
#9 Posted : Monday, March 25, 2013 4:17:58 PM(UTC)
nckrauel
nck
Guest (5)
Whirlpool Refrigerator Freezer Coils Icing up (Refrigerator & Freezer Repair)
by aarrington 2/25/2022 5:39:48 AM(UTC)
Whirlpool Refrigerator Freezer Section Intermittently Not Cooling or Making Ice (Refrigerator & Freezer Repair)
by dreeves1822 2/4/2021 6:05:32 AM(UTC)
GX2FHDXVB00 whirlpool refrigerator freezer not freezing (Refrigerator & Freezer Repair)
by Nwhe54 12/21/2020 8:30:23 AM(UTC)
Whirlpool Refrigerator Freezer Not Working (Refrigerator & Freezer Repair)
by srbr 8/6/2015 6:24:04 PM(UTC)
whirlpool refrigerator freezer (Refrigerator & Freezer Repair)
by debbie727 12/12/2011 2:26:02 PM(UTC)
