applianceissues
#1 Posted : Monday, March 11, 2013 8:38:32 AM(UTC)
applianceissues
I need to replace my dryer belt bc the dryer doesn't tumble. How do I get to the inside of the dryer in order to put the new belt on? Somebody please help me, I have a ton of laundry to do!!
Simon / APP Team
#2 Posted : Monday, March 11, 2013 11:47:09 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Unplug the dryer.
Locate and remove two screws at the bottom portion of the front panel. Pull the lower portion of the panel out and release it from the top clips.
Remove the 4 screws holding the bulkhead and remove the bulkhead.
Go to the back of the dryer, locate and remove the square cover in the right lower corner.
Memorize the way the belt is installed if it's still installed, take it off the pulleys.
Return to the front and remove the old belt. Put the belt on. The grooves on the belt should be facing outside.
Part number: AP4290988
Here are the breakdown diagrams and 07-Rear View parts for Maytag DE313 - AppliancePartsPros.com
Post the results.
Simon.
Belt replacement help (Dryer Repair)
by dccharles 4/12/2010 11:58:00 AM(UTC)
