pamtimpam
#1 Posted : Sunday, March 10, 2013 1:50:32 PM(UTC)
pamtimpam
My ice maker freezes good, freezer keeps everything frozen good, freezer fan runs all the time . After a few hours ice starts clumping together I have checked for leaks and it has none ca you help me?
#2 Posted : Sunday, March 10, 2013 2:41:38 PM(UTC)
If ice cubes are clumping together then it is probably not cold enough.
Check the freezer temperature, should be between 0 and 5 decrees F.
Is the compressor and it's fan running all the rime?
You can usually hear the compressor but you should also be able to feel it vibrating and it should be warm.
If the freezer temperature is too warm check that the condenser.compressor fan is running. Also that the condenser coils under the unit are clean and that the vents in the front kick plate and rear cover are clean.
