scooty1
#1 Posted : 12 years ago
scooty1
There is water in the tub. I see it spinning when open the lid on rinse cycle. It stops and does not advance past rinse cycle. Problem most likely?
scooty1
#2 Posted : 12 years ago
scooty1
could it be the timer?
fairbank56
#3 Posted : 12 years ago
fairbank56
Groups: Expert
Need the proper model number and more details on the problem. Normal chain of events is; fills, agitates, drains, spin/drain, repeats for rinse cycle.
Eric
scooty1
#4 Posted : 12 years ago
scooty1
where is the model number? I couldnt find one
fairbank56
#5 Posted : 12 years ago
fairbank56
Groups: Expert
It's usually under the lid somewhere.
Eric
scooty1
#6 Posted : 12 years ago
scooty1
I don't see one
scooty1
#7 Posted : 12 years ago
scooty1
Model:LSR7233E00 SERIAL:CF4433761
fairbank56
#8 Posted : 12 years ago
fairbank56
Groups: Expert
Ok, we have the model number. I'm not clear on the problem. Wash cycle, fill, agitate, drain, spin/drain, rinse cycle fill, agitate, drain, spin/drain. What and where in the cycle is the problem?
Eric
scooty1
#9 Posted : 12 years ago
scooty1
I am not standing there but it was full of water and the timer did not make it to spin yet. The timer had advanced past the time funtion and was close to or on rinse. Maybe I need to do some more testing? And thanks for responding.
fairbank56
#10 Posted : 12 years ago
fairbank56
Groups: Expert
Yes, need to know if it is agitating and what it's doing after that when it should be draining (motor quiet? humming?...etc.).
Eric
