How2install GE Ceramic-Glass Cooktop AP3207250 Model Number: JS968TF1WW Brand: GE Age: 5 - 10 years :( I would like to know how to install this cook top.
Do I need to uninstall the control panel in front of the stove to take the screws out and lift the glass? And if I do, How do I do this without messing it up, it is all computerized.
When I installed this stove, I did not add any glue whatsoever. However, is there any ungluing needed to uninstall or install this cook top or the control unit if that needs to be taken off?
The glass on the top right and the back right burners are cracked. Is it safe to use the other two burners until I can buy the new unit?
Thank you,
Jeff Andrew
