rabatvilla
#1 Posted : Thursday, March 7, 2013 5:08:51 PM(UTC)
rabatvilla
I have a very nice early 1950s oven with the broiler not working. I get 125V on the black. I also get 125V at the oven selector switch on all blacks and red connected to it when turned to broil. I also get 125V on the white leading from the broiler element back to the selector switch. I have also found I can get 50V if I place meter between the element itself and the frame. The bottom element works fine, that I get 250V across the element ends. Not to sure if the selector switch is bad or what? Please help
Thank you
It's a GE not a Frigidaire. Selected the wrong band by mistake
#2 Posted : Friday, March 8, 2013 4:06:01 PM(UTC)
Hello,
I believe it suppose to be 240 VAC to the broil heating element as well. Unfortunately I'm not able to find any diagrams, schematics and/or parts list for such old product.
rabatvilla
#3 Posted : Friday, March 8, 2013 5:07:05 PM(UTC)
rabatvilla
Yes, it suppose to have 240 across the element. I have the schematic and I thinks the selector switch contacts are bad but am not sure. I am wondering if the thermostat could be the issue? The bottom element heats up very quickly. Finding parts is a bit of a pain for this.
Joe
rabatvilla
#4 Posted : Friday, March 8, 2013 6:29:10 PM(UTC)
rabatvilla
Hello
I fixed it. Took the selector switch apart and cleaned the contacts one of which was bad. It works for now but I will need to find a good used switch. Older GE with Bake, Timed bake, and broil.
#5 Posted : Monday, March 11, 2013 1:17:11 PM(UTC)
Hi Joe. I'm glad to hear you were able to fix it. What is the part number form the old selector switch?
rabatvilla
#6 Posted : Monday, March 11, 2013 3:37:21 PM(UTC)
rabatvilla
It is either a WB22X15 or an X25. Since there is no part number on the elector switch it's hard to tell. What I have to go off of is there are three settings, Bake, Time Bake,a nd Broil. When the switch is turn to either one of those a light comes on for the thermostat. On the back there are eight wire connections, and on the inside 4 sets of contact points.
Thank you for your help
#7 Posted : Tuesday, March 12, 2013 10:37:13 AM(UTC)
I've tried both part numbers and no one comes up. You may want to take the old part to a local appliance parts store to match it up.
Guest (9)
