washer will not drain,so far have replaced timer and lid lock switch.at first it woulnd not spin .pulled pump checked lines fore and aft for clogs all is clear took pump apart no clogs spins free.reconnected,to washer and put on spinn cycle washer spun but pump did not kick on.any help on what to do next.is there a way to test elec part of pump
Groups: APP Team
Hi. You should check if the pump is getting the 120VAC when the timer is set to drain. If there is correct voltage to the drain pump and it's not working - replace the pump. If not then check the wire harness and connectors to the timer. Checks OK - replace the timer. Here are the breakdown diagrams and Control Panel parts for Frigidaire FEX831FS4 - AppliancePartsPros.comPost the results. Simon.
Originally Posted by: Simon / APP Team  Hi. You should check if the pump is getting the 120VAC when the timer is set to drain. If there is correct voltage to the drain pump and it's not working - replace the pump. If not then check the wire harness and connectors to the timer. Checks OK - replace the timer. Here are the breakdown diagrams and Control Panel parts for Frigidaire FEX831FS4 - AppliancePartsPros.comPost the results. Simon. replaced timer and lid switch pulled pump and ran it direct and it ran fine checked for obstructions fore and aft and found nothing
Groups: APP Team
Did you check for 120VAC to the pump?
Simon.
Originally Posted by: Simon / APP Team  Did you check for 120VAC to the pump?
Simon. yes i did it is gettin it
