chefchappel@msn.com
#1 Posted : Tuesday, March 5, 2013 11:59:15 AM(UTC)
chefchappel@msn.com
Oven door does not completely close, no obstructions. Problem has existed for over a year, sometimes while in use the oven light comes on and the oven stops heating. Can the hinge springs be adjusted? Thanks for your help.
Simon / APP Team
#2 Posted : Tuesday, March 5, 2013 1:48:46 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The door spring cannot be adjusted - you need to replace them as part of the door hinges. Sometimes the inserts (receivers) also should be replaced.
Please check the model number, the one you have provided doesn't come up.
Simon.
chefchappel@msn.com
#3 Posted : Tuesday, March 5, 2013 5:38:45 PM(UTC)
chefchappel@msn.com
Thanks Simon. The model # is KESS907SSS00. You mentioned replacing the inserts as well, where are they located and are they hard to get to.
Simon / APP Team
#4 Posted : Wednesday, March 6, 2013 8:38:34 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The receivers (inserts) are the parts where the hinges are going into. To replace them you will need to pull the oven few inches out.
This is the left side Part number: 4455605
For the right side use Part number: 4455606
The hinges for the st. steel door Part number: 9760579
Here are the breakdown diagrams and Oven parts for Whirlpool KESS907SSS00 - AppliancePartsPros.com
Post the results.
Simon.
chefchappel@msn.com
#5 Posted : Wednesday, March 6, 2013 7:24:28 PM(UTC)
chefchappel@msn.com
Thanks Simon, very helpful!
Simon / APP Team
#6 Posted : Thursday, March 7, 2013 8:45:29 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Jenn Air oven door does not close all the way (Oven Repair (including Ranges and Cooktops))
by Meyekal 10/4/2011 8:49:54 AM(UTC)
Oven Door Does Not Close All the Way (Oven Repair (including Ranges and Cooktops))
by jas227 4/2/2008 6:05:45 AM(UTC)
