proteus
#1 Posted : Monday, March 4, 2013 12:15:13 PM(UTC)
proteus
Sorry I do not have the Model number at hand. The problem i am having is this. It will go through a full cycle of wash and rinse and when finished instead of stopping it will start to fill again like it is going to start another load.:confused:
fairbank56
#2 Posted : Monday, March 4, 2013 1:14:36 PM(UTC)
fairbank56
Groups: Expert
We must have the full model number to be able to help you.
Eric
proteus
#3 Posted : Tuesday, March 5, 2013 5:02:27 AM(UTC)
proteus
I was able to get the model number last night.
MTW5830TW0
fairbank56
#4 Posted : Tuesday, March 5, 2013 6:07:16 AM(UTC)
fairbank56
Groups: Expert
Sounds like options is set for extra rinse cycle? If extra rinse is not set, will it do this continously? You have to turn it off to make it stop? If that is the case, I'd say you have a bad timer. If it just seems to be running an extra rinse cycle with the extra rinse function off, it could be the options switch.
Eric
proteus
#5 Posted : Tuesday, March 5, 2013 6:46:51 AM(UTC)
proteus
To determine wether it is the timer or switch, I need to let it fill and see if it goes to another rinse cycle or goes into a full wash cycle?
fairbank56
#6 Posted : Tuesday, March 5, 2013 7:26:14 AM(UTC)
fairbank56
Groups: Expert
Just disconnect the extra rinse cycle switch, put the timer near the end of the normal rinse cycle and see what happens.
Eric
proteus
#7 Posted : Tuesday, March 5, 2013 7:50:16 AM(UTC)
proteus
Will do. Thanks for all of the help.
proteus
#8 Posted : Wednesday, March 6, 2013 9:41:24 AM(UTC)
proteus
problem solved. my wife had it set on the extra rinse option:o
