rfbarnett
#1 Posted : Sunday, March 3, 2013 10:52:42 AM(UTC)
rfbarnett
We bought this unit for the A//C five years ago, and thought the heating feature might be useful in our old farmhouse. As home heating oil prices rose, we used the heater more and more. Now it has quit heating. Cleaned the filter, still no heat. Think about replacing the heater element? I see it's kinda pricey. Thanks for your help.
#2 Posted : Monday, March 4, 2013 1:47:49 AM(UTC)
Here are your parts, includes a wiring diagram.
Parts for FAM18EQ2A - AppliancePartsPros.com
Here is info on PTC heaters.
I would check it with a meter. Unfortunately I do not have info on what the resistances at different temperatures should be.
Start with a low meter scale and then increase it if you get infinite ohms.
If it has resistance then it could be the power relay (RLY3) is bad or the electronics that control the relay are bad.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
rfbarnett
#3 Posted : Monday, March 4, 2013 2:56:37 AM(UTC)
rfbarnett
thanks denman
jhonson smith
#4 Posted : Tuesday, May 5, 2015 1:23:31 AM(UTC)
jhonson smith
If your thermostat has a switch to control the furnace fan, switch the fan "ON". Listen to hear the furnace fan coming on. If you cannot hear the fan, go to one of the supply registers and see if you can feel any air coming out. If the fan is not running, there may be no power to the furnace. If the thermostat is set properly, next step is to check to see that there is power to the furnace.Your heating system may be equipped with an emergency shut-off switch for the furnace. If your Air Conditioning System is so equipped, locate it and make sure it is turned on. Check to make sure all access doors are properly secured and fitted.
