Bubmblebee83
#1 Posted : Friday, March 1, 2013 10:38:10 AM(UTC)
Bubmblebee83
The top arm of my dishwasher will not move. It rotates freely when the dishwasher is off but remains stationary during the dishwasher cycle. How do I fix this?
#2 Posted : Friday, March 1, 2013 4:40:55 PM(UTC)
What is the water level in the dishwasher during the wash cycle?
Try to add 1/2 of gallon of water and see how it will work.
Here are the breakdown diagrams and Parts for Whirlpool DU948PWKB0 Dishwasher - AppliancePartsPros.com
Cole Elliott
#3 Posted : Friday, March 1, 2013 4:50:41 PM(UTC)
Cole Elliott
Are the dishes clean
Bubmblebee83
#4 Posted : Saturday, March 2, 2013 12:27:22 PM(UTC)
Bubmblebee83
The dishes are not coming clean on the top rack, in fact, they are dirtier coming out than going in, except right along the stationary spinner arm. I have tried adding water with no different results. I have tested the water inlet valve for electrical continuity. The float appears to be working correctly. I have tried Dishwasher Magic to reduce the food particles. The water temperature is plenty hot. Anxiously awaiting a possible solution. What is the expected life span of this dishwasher? Thanks for your help.
#5 Posted : Monday, March 4, 2013 12:23:53 PM(UTC)
Make sure the upper spray arm manifold (#11 at the diagram) is in place and is properly connects to the water outlet.
Remove the upper dish rack and the water supply tube. Remove the pump outlet (#14 at the diagram) and check the impellers.
