gj2001
#1 Posted : Friday, March 1, 2013 2:26:38 PM(UTC)
gj2001
I've had the oven approx 5.5yrs.
1) Oven will not shut off
2) With power applied and the oven temp control set to off, the igniter glows
3) When the input gas valve is open the oven is on continuously
4) Replaced the igniter, no change
5) The top burners all ignite when turned on
6) It seems that when power is applied that the oven valve is always open.
7) Can the thermostat, part number WB20K0008, cause this issue?
8) Currently the input gas valve is closed and the AC power is disconnected.
9) Thank you in advance
gj2001
#2 Posted : Friday, March 1, 2013 2:28:44 PM(UTC)
gj2001
Note: i should have included that I replaced the igniter but that did not resolve the issue.
