My stackable washer isn't starting, but dryer works fine. What is the likely part to be defective?
Originally Posted by: changa ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My stackable washer isn't starting, but dryer works fine. What is the likely part to be defective? Changa, The first thing to check, is the lid switch assembly Part number: AP2947199
and wiring to the washer portion of the laundry center.
Groups: Expert
Does it fill with water? I believe the lid switch on the thin twin washers only effects drain and spin.
Eric
Originally Posted by: fairbank56 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Does it fill with water? I believe the lid switch on the thin twin washers only effects drain and spin.
Eric You're corret, my mistake. If the washer won't fill or wash, then there would be a broken black wire, between the timer and line cord connections or a faulty timer Part number: AP2974739
