My Whirpool washer after the lid down only listen the timer click, but the washer doesn't work (agite/spin).
when I change the capacity washer indicator, the washer fill fine I'm not sure about the model number, only I identified the follow description: "Perfect care Excell Drive 8 cycles"
In order to provide most accurate advice we need the complete model number of the washer. You can find it under the lid.
