mnorth05
#1 Posted : Sunday, February 24, 2013 5:10:42 PM(UTC)
mnorth05
dishwasher fill pause and start to wash then stop pause then start to wash and stop then shut down need help whats wrong
#2 Posted : Monday, February 25, 2013 2:46:28 PM(UTC)
Hello,
How long were the time intervals for wash and pause?
Did it show anything on the control panel like blinking lights?
Here are the breakdown diagrams and Parts for Maytag MDBH940AWS Dishwasher - AppliancePartsPros.com
mnorth05
#3 Posted : Tuesday, February 26, 2013 3:14:56 PM(UTC)
mnorth05
no lights shut off on third time , start to wash about 3sec stop for 3sec start 3sec the stop for 3sec then light out.hit cancal will drain.but what seem like on third try of washing it lock out light out nothing untill you turn power off and restart it again i think its control board thank gene
mnorth05
#4 Posted : Tuesday, February 26, 2013 5:02:04 PM(UTC)
mnorth05
Hello,
3sec each on third try lights go out nothing but if you hit can it will drain
#5 Posted : Tuesday, February 26, 2013 7:15:18 PM(UTC)
Measure the current drawn by the motor when it's running.
If the reading is around 2.5 amps, replace the control board.
If the reading is different, replace the pump & motor assembly.
- The control board Part number: 12002713
- The pump & motor assembly Part number: 6-919922
Frigidaire dishwasher code A (Dishwasher Repair)
by Evandtam 6/27/2024 5:11:41 PM(UTC)
Fisher Paykel Drawer Dishwasher will not Lock (Dishwasher Repair)
by thompsdw 6/17/2024 7:34:54 AM(UTC)
Dishwasher won't work. (Dishwasher Repair)
by Guest 5/23/2024 6:32:18 PM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
