Moesmom
#1 Posted : Sunday, February 24, 2013 2:32:45 PM(UTC)
Moesmom
Does not drain. It does spin. We did take the pump off and the fin turns very hard. Suggestions. :confused:
#2 Posted : Monday, February 25, 2013 1:59:59 PM(UTC)
Hello,
Check for 120 VAC to the pump while the timer calls for drain. If the reading is correct, replace the pump.
- The drain pump Part number: WH23X10013
Here are the breakdown diagrams and Parts for GE WCSE4160B0WW Washer - AppliancePartsPros.com
Water is left in washer, door is locked cannot open, does not drain, clothes still wet (Washer Repair)
by Guest 12/4/2022 11:52:36 AM(UTC)
washer does not drain (Washer Repair)
by lukasage 8/31/2015 4:42:43 AM(UTC)
Washer does not drain (Washer Repair)
by erichawkinsa 3/30/2014 6:10:08 PM(UTC)
Dishwasher does not drain completely (Dishwasher Repair)
by jlobb2 12/4/2013 2:42:17 AM(UTC)
by jlobb2 12/4/2013 2:40:46 AM(UTC)
Does not drain (Dishwasher Repair)
by SFPhoto 11/17/2013 8:40:13 AM(UTC)
Whirlpool Quiet Partner II does not drain (Dishwasher Repair)
by JosephC 11/12/2013 2:30:21 PM(UTC)
Whirlpool dishwasher does not drain (Dishwasher Repair)
by valv00 3/30/2013 5:05:23 PM(UTC)
Fridgidaire Gallery Does not drain water (Washer Repair)
by Abe460 12/30/2012 4:58:39 PM(UTC)
Water does not drain completely (Dishwasher Repair)
by g11171 9/17/2012 5:28:01 PM(UTC)
Whirlpool Washer does not drain (Washer Repair)
by L-Squared 8/13/2012 4:31:44 PM(UTC)
Jenn Air Dishwasher does not drain completely (Dishwasher Repair)
by jjdoc 6/26/2012 11:41:48 AM(UTC)
Washer puts water in drum does not turn only hums and water does not drain (Washer Repair)
by vsquared 6/23/2012 7:09:22 PM(UTC)
dish washer does not drain completely (Dishwasher Repair)
by billnheather 5/27/2012 5:33:36 PM(UTC)
MAH6500AWW ND CODE. Does not drain. (Dishwasher Repair)
by Rocketboz 5/25/2012 8:17:59 PM(UTC)
