I have a top load washer that the tub is loose. In order to get the right fix and parts determined.....First....Where will I find the model number? I have looked all over the unit including under the lid. Thank you
Originally Posted by: dp2763  I have a top load washer that the tub is loose. In order to get the right fix and parts determined.....First....Where will I find the model number? I have looked all over the unit including under the lid. Thank you Lean over the washer and look on the ledge behind the timer. It, the serial # REV # are on the very small ledge where the back of the machine meets the top.
