whiley23
#1 Posted : Friday, February 22, 2013 11:56:55 AM(UTC)
whiley23
I had to disconnect all the wires from the timer switch and am having trouble figuring out where they go to put them back on. There are 6 posts labeled A. B. C. TM. TD. AD. there are two black wires coming from the switch. 1 tan wire, 1 orange wire, 1 red wire, 1 white wire, 1 pink wire, and 1 green wire with a larger spade than the rest. i have the original wiring diagram but it is useless or i cant read it. please any advice or pics on this would be much appreciated.
Simon / APP Team
#2 Posted : Friday, February 22, 2013 12:25:53 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Here the connection by the color code:
A-ORANGE
B-RED
C-WHITE and BLK from the timer motor
AD-PINK
TD-2 TAN wires
TM-BLK from the timer motor
GRN wire connects to the ground connector
Simon.
whiley23
#3 Posted : Friday, February 22, 2013 1:28:40 PM(UTC)
whiley23
thanks alot simon. where is the ground connector?
Simon / APP Team
#4 Posted : Thursday, February 28, 2013 10:42:21 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Sorry for the delay - I was out of the town.
The ground connector is on the timer and should be attached to the timer's top metal plate.
Simon.
