5 Pages<12345>
away
#21 Posted : 13 years ago
away
Originally Posted by: drew85205 Go to Quoted Post
Just curious, how much did the service call cost?
$69.95, reasonable, except that I was not convinced the control board is the culprit. And next day I was given an estimate/quote of $440 for fixing the problem.
Joe / APP Team
#22 Posted : 13 years ago
Joe / APP Team
Originally Posted by: away Go to Quoted Post
Don't know where my post went, I will try again.
I am having same problem ("oL") with my Whirlpool Cabrio Washer (wttw6600sw0). The scenario is that the washer does not stop filling water during Wash cycle, it appears being stuck after Wash cycle begins for 10 mins, hence, overloaded with water. Spin and drain appear OK.
I'd ordered and replaced the RPS kit(AP4327312) even though there was not any sign of leakage nor damage, situation does not improve. I also ordered and replaced its processor/control board (W10189966), no improvement either.
Ran manufacturer's manual diagnostic test (#6) that supposed to recalibrate the water level and Pressure Transducer.
Failed manufacturer's automatic diagnostic test C1.
A Maytag repair person came on site and charged me for a house call, his initial conclusion was that I need to replace the control board (which I did already) and quoted me $400+ to fix it. Upon knowing the board is replaced, he mentioned that the board's memory still needs to be reset. Any truth to this?
Please help!
Thanks.
Away
Away,
You have checked and made sure you have good water supply and pressure to the fill valve, from the faucets, and a valve solenoid is not "sticking" open, a quick easy check, unplug the power cord, while the washer is filling in a warm water wash.The valve should "snap" shut.
We're not aware of a need to "reprogram" a new CCU/control board, when replaced. But you can test and recalibrate the water level transducer, if needed, but that's not a normal occurrence either.
You have checked and made sure there are no twists, kinks, holes or loose air dome hose connections, correct. ? You also want to disconnect the air tube from the tub and check the tub connector for deposits and debris, restricting the air flow into and up the tube. and make sure the retainer clip and screw are not too tight or pinching the tube.
Thanks and Good Luck,
ptesmoke
#23 Posted : 12 years ago
ptesmoke
I managed to repair my cabrio (basket was stuck on filthy drive shaft ) but I would like to know if I can clear the codes that it caused? or are they forever in the memory?
Joe / APP Team
#24 Posted : 12 years ago
Joe / APP Team
Ptesmoke, Sorry, the error codes are retained by the memory chip in the control board. The number of error codes is limited, and the older codes will "drop out" and be replaced the the newer codes, the most recent code being first.
Thanks,
ptesmoke
#25 Posted : 12 years ago
ptesmoke
awesome thanks for the quick reply!
for anyone's reference in the future...I had f41 and f51 fault codes, running diag check failed on c1 with an oL fail code.
f41 and f51 indicated an rps sensor problem, further investigation found that the basket was stuck in the up most position, followed the manual to disassemble as I was sure the basket being stuck was causing the rps sensor to err out during a normal wash cycle. also note I had no agitation during a normal cycle.
once basket was loosened enough to remove the obvious fault was corrosion on the drive shaft. cleaned and now she works perfect all thanks to allot of info I found here.
cheers and hope my experience helps someone!
Joe / APP Team
#26 Posted : 12 years ago
Joe / APP Team
Ptsmoke,
You're Welcome
and Thank You for your update / report. It should be very helpful to those who have a similar issue, once they find their way to the Repair Forum.
Thanks Again,
BrotherBear
#27 Posted : 12 years ago
BrotherBear
I had a oL error code (overload code) on my Whirlpool Cabrio. The basket (drum) was not floating up to disengage from the shaft when it was supposed to. The basket should be able to slide up and down independently of the agitator about 1/2 inch when lifted. I was able to remove the agitator as shown here
with little effort. But when I tried to pull the basket up and off the shaft it wouldn't budge. I was able to free it by lifting the basket up with one hand while pounding on the end&#65279; of the shaft with a 3 foot long 4x4. I found that the shaft had rusted to the basket. I sanded up the shaft. Now it works perfectly with no oL code.... until it rusts again someday on that nicely sanded shaft.
Joe / APP Team
#28 Posted : 12 years ago
Joe / APP Team
Originally Posted by: BrotherBear Go to Quoted Post
I had a oL error code (overload code) on my Whirlpool Cabrio. The basket (drum) was not floating up to disengage from the shaft when it was supposed to. The basket should be able to slide up and down independently of the agitator about 1/2 inch when lifted. I was able to remove the agitator as shown here How to replace the tub and bearings on a Whirlpool Cabrio (Old Way) - YouTube with little effort. But when I tried to pull the basket up and off the shaft it wouldn't budge. I was able to free it by lifting the basket up with one hand while pounding on the end&#65279; of the shaft with a 3 foot long 4x4. I found that the shaft had rusted to the basket. I sanded up the shaft. Now it works perfectly with no oL code.... until it rusts again someday on that nicely sanded shaft.
BrotherBear, Thanks for your update. We're glad things went well for you.
Everyone here on the Forum appreciates the updates and service Information and experiences. No repair is exactly the same, evry little bit helps. Thanks Again
nicholasp
#29 Posted : 11 years ago
nicholasp
hi
this Is related to the whirlpool cabrio washer ... giving "ol" error.
A couple weeks ago I bought this washer from my neighbor And it was working fine.
Then when I moved it to my place ( we actually just used a buggy so there was hardly any chance of damage in the move )
I set it up and made sure that it is absolutely level etc.
And now I am getting the "oL" error :(
I am thinking the only thing that could be the cause is that in my laundry room on the floor I havethose "spongy" tiles that we find that day care centers ( 24" x 24" multicolored etc. ) I did put it on a piece of wood… But I'm thinking that maybe when the washer fills up and started cycle it detects instability and triggers the "ol"
Does this make any sense or is it truly seem that I was so unlucky that moving it from across the street damaged it somehow.
thanks
Joe / APP Team
#30 Posted : 11 years ago
Joe / APP Team
Originally Posted by: nicholasp Go to Quoted Post
hi
thanks
Nicholas, You may want to check the wires to the RPS switch and make sure they didn't get dislodged or knocked loose in the move. But that's the least of your worries. You'll have to do something about the floor tiles, you need to remove them, basically. This style washer has to be installed on a good solid floor(depending on the condition of the floor, you may have to reinforce it as well). The way the tubs are suspended and the design of the washer, any movement or vibration is transferred from the tub to the cabinet, from the cabinet to the feet, and from the feet to the floor. If the floor isn't solid enough the washer will shake, and the tub won't come up to speed, and you'll get the "OL" (over loaded) error code.
Of course, you also need to make sure the washer isn't being overloaded, never fill it more than 2/3 full with dry clothes, for proper operation and cleaning performance.
5 Pages<12345>
