WarFox101
#1 Posted : Tuesday, February 19, 2013 8:11:38 PM(UTC)
WarFox101
Hi, I was working on my ice maker, The spring came off the flapper that turns off the ice. I unplugged the ice maker before unplugging the frig. Very stupid I know. The lights works when I open the doors. the ice maker light is on, the ice maker screw turns when I press the button. the water works fine The frig wont turn on and start cooling.
I repair computer motherboards for a living so I know about electronics I just need to know what to check. Could my control board be bad or is it a sensor problem? Thanks in advance.
WarFox101
#2 Posted : Wednesday, February 20, 2013 12:03:14 AM(UTC)
WarFox101
Update: The frig works fine now except the fan on the inside of the freezer is not spinning. I tested the control boards j2 connector, pin 3 and 8 and got 12v DC. I also tested pins 3 and 4 and got 12v DC. Am I right in saying I have a bad evaporator fan? Also I tested the defrost thermostat and found no resistance so I found the problem there. Any thoughts or second opinions? Thanks in advance.
#3 Posted : Thursday, February 21, 2013 3:26:31 PM(UTC)
Hello,
The main control board is bad.
I'm not sure which part did you call "defrost thermostat". Is it the overtemperature thermostat (#240 at the diagram)? If that is correct and the continuity test shows it's open, then it will cause the refrigerator not defrosting.
- The main control board Part number: WR55X10942
- The overtemperature thermostat Part number: WR50X10069
