My ice maker started started developing "ice dams" that would flow down the back all the way to the fan. We had to remove them by hand more then once. A couple of times it flowed into the bin and freezing the arm in place. Now it has stopped working all together except for about 6 cubes ounce every 1 to 2 days. everything else works fine ie water dispenser, crushed/cubed and auger.
Hello, Sounds like the problem is a bad water inlet valve on the back of the refrigerator. - The water inlet valve Part number: WR57X10032
