Good evening,
I am experiencing an issue with the "in door" water dispenser. I have completed a few troubleshooting tasks however, the problem hasn't resolved.
I have: Cycled the power, Looked at the back of unit for water, leaks in connections and hose - none. Took the water filter out, emptied it, and returned it. ( I do change out my filter when the unit let's me know. The filter that is currently being used did work before today) Changed the tempature settings in both sides, made it warmer. Left the ice maker on, and emptied out all of the ice.
I am turning to you for help in this matter. I thank you in advance.
This morning, I noticed that ice was being made. I pressed the switch for the water, and I hear a click but sadly, no water comes out. Any ideas. The correct model number is gsh25sgress
