gleeper
#1 Posted : Thursday, February 14, 2013 9:13:30 PM(UTC)
gleeper
ongoing issues with this dryer.
few weeks ago it stopped heating. would spin, but no heat.
continuity checked out fine for thermostats and heating coil, turned out to he the control board (faulty relay)
Bought a new control board here swapped it worked great for a week.
Today the dryer shuts off 1 second after starting.
If i select "no heat" option the dryer will spin, but when i select low, med or high heat it starts, spins for 1 second and shuts off.
diagnostic error code seems to he a 95 but i cant find any info on that.
any help is much appreciated.
thanks
#2 Posted : Friday, February 15, 2013 2:36:28 PM(UTC)
Hello,
Perform the test described on the first page of the attached tech sheet and post the results.
Post the end of the model number.
File Attachment(s):
gleeper
#3 Posted : Friday, February 15, 2013 3:38:39 PM(UTC)
gleeper
thanks Gene,
I did that test and unless I am reading it wrong I am getting an error code 9 - 5
Full Model # is feq1442ces-0
#4 Posted : Friday, February 15, 2013 4:21:37 PM(UTC)
There are no such error codes listed.
I would like you to redo this test and post the results as well as step by step description on how you did it.
gleeper
#5 Posted : Friday, February 15, 2013 5:45:54 PM(UTC)
gleeper
turned the selection knob to 3 oclock.
held down 2 buttons 6 seconds.
held down 2 buttons 4 seconds.
Turned knob to 2 oclock
http://www3.telus.net/public/gl3771/20130214_214117_NEW.wmv
here is a video file of the results
hopefully you can d/l or view, or let me know if there is a better way to send this to you.
thanks for all the help its much appreciated!!!
#6 Posted : Tuesday, February 19, 2013 4:11:18 PM(UTC)
Sorry for the delay.
It looks very strange to me either.
I would recommend to check the thermistor (#15 at the diagram). The normal reading suppose to 50K ohms ± 10%.
- The thermistor Part number: 134587700
gleeper
#7 Posted : Tuesday, February 19, 2013 10:57:12 PM(UTC)
gleeper
No worries Gene, I appreciate any help i can get.
I did swap the thermister a few weeks ago as i thought that may have been the issue with it when it was not heating, so it is new... I didn't get a continuity reading from that before.
curious what would cause that to blow?? if i have gone through 2 in a matter of weeks then i assume i have a bigger root problem.
thanks
#8 Posted : Wednesday, February 20, 2013 2:46:59 PM(UTC)
Check the thermistor again but do it from the control boar by measuring resistance between the terminals J2-4 & J2-5 at the control board.
Post the results.
What is the part number of the control board you installed?
Guest (7)
Ge Dryer wont spin (Dryer Repair)
by chapin86 6/19/2012 6:58:23 PM(UTC)
Maytag Neptune Combo Washer/ Dryer wont spin (washer) (Washer Repair)
by HLSerrano 3/3/2012 7:29:44 AM(UTC)
by scorpiogrl27 3/9/2010 9:57:21 AM(UTC)
Whirlpool Dryer wont spin (Dryer Repair)
by Copeland7 2/24/2010 10:19:02 AM(UTC)
Whirlpool gas dryer wont spin (Dryer Repair)
by DennisLu 2/23/2010 5:55:19 PM(UTC)
thanks to hubby my dryer wont spin (Dryer Repair)
by courtnij 10/26/2009 10:45:14 AM(UTC)
by brownmann08 9/10/2009 7:40:12 AM(UTC)
Stacked Washer/dryer Wont Spin/burn Smell (Washer Repair)
by rustknee 3/7/2008 10:15:01 AM(UTC)
