I have replaced both the control and the 6 button switch due to the fact the lights do not come on the 6 button switch and also the drying cycle does not dry but you can feel it is warm inside the machine. what could cause this problem:mad:
Originally Posted by: vheitz ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I have replaced both the control and the 6 button switch due to the fact the lights do not come on the 6 button switch and also the drying cycle does not dry but you can feel it is warm inside the machine. what could cause this problem:mad: Vheitz, you're going to need to check for proper voltage to the dishwasher at the junction box on the lower frame, behind the kick plate. and also check the wiring harness connections at the timer and the selector switch. If you have a frayed wire, or loose connection on the terminals, the voltage could be low and intermittent, causing the lights to not illuminate and not enough voltage to oprate the heater element.
