ayconsulting@shaw.ca
#1 Posted : Wednesday, February 13, 2013 1:06:56 PM(UTC)
Hi there, my turn table won't turn at all. We looked at the piece underneath the plate and it is not cracked but I can pull it up as it's loose, not sure if this is normal. How can we get it to turn? Thanks.
Simon / APP Team
#2 Posted : Wednesday, February 13, 2013 1:49:22 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you checked the coupler and it's OK then open the bottom cover and locate the turn table motor Part number: WB26X10038
Take the two wires off it and use the voltmeter to check for 21VAC across the wires with the MW turned on.
If the correct power is present - replace the motor, if not - replace the control board Part number: WB27X10655
Here are the breakdown diagrams and Microwave parts for GE JVM1430WD001 - AppliancePartsPros.com
Post the results.
Simon.
