JULES52
#1 Posted : Tuesday, February 12, 2013 9:40:05 PM(UTC)
JULES52
My control panel for the oven and clock/timer will give a F1-1. This happens when I use the cook top or the oven, and shuts off the oven if it is in use. I've been told this is the touch pad, and was sent the push pad face lens. Is it the clock pad that is under the push pad face?($293.00)
#2 Posted : Wednesday, February 13, 2013 1:22:10 AM(UTC)
Parts for Maytag MER6770AAB Range - AppliancePartsPros.com
When I look up F1-1 it comes up as an upper oven temperature runaway.
So I would start by checking the oven sensor.
Here is a good link on how to do this, look at 7, 8, 20 and 21.
http://www.applianceaid.com/electric-range-repair-topics.php
If OK then I would replace the control board/timer (item 3 in the Control Panel Parts section). You may still need the overlay as sometimes the old one does not come off undamaged.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Guest (4)
LG control panel issue (Dishwasher Repair)
by Guest 9/10/2023 7:18:58 AM(UTC)
GE Profile Refrigerator Dispenser Control Panel Issue (PFSS6PKXESS) (Refrigerator & Freezer Repair)
by Geprofileman 6/24/2021 6:45:46 AM(UTC)
Frigidaire Gallery FGGF3054MFF Control Panel Issue? (Oven Repair (including Ranges and Cooktops))
by Greyhound88 2/3/2017 6:17:02 PM(UTC)
HELP!! Control Panel Issues (Dishwasher Repair)
by claudinemdepaul 7/1/2012 3:26:52 PM(UTC)
FRIGIDAIRE WASHER control panel issue? (Washer Repair)
by BRAD974 5/28/2011 8:44:34 AM(UTC)
Control Panel Issues (Oven Repair (including Ranges and Cooktops))
by paule10204 1/10/2011 11:55:58 AM(UTC)
Whirlpool Wall Oven control panel issues (Oven Repair (including Ranges and Cooktops))
by spkolluri 11/24/2010 10:55:48 AM(UTC)
Control Panel Issues (Washer Repair)
by dkirks 10/21/2010 10:09:56 AM(UTC)
Jenn air Control Panel issue (Oven Repair (including Ranges and Cooktops))
by CShort5 2/13/2010 4:58:02 AM(UTC)
Control panel issues (Oven Repair (including Ranges and Cooktops))
by jgootz 1/19/2010 1:07:55 PM(UTC)
Jenn Air oven control panel issues (Oven Repair (including Ranges and Cooktops))
by tychaney 11/12/2009 12:57:11 PM(UTC)
Whirlpool Control Panel Issue? (Dishwasher Repair)
by bermanbj 8/26/2009 7:47:28 AM(UTC)
Installed today, control panel issues or just me? (Dishwasher Repair)
by Kodge 7/25/2009 5:28:35 PM(UTC)
GE Profile Artica Fridge-Control Panel issue? (Refrigerator & Freezer Repair)
by edeluca62 2/24/2009 2:52:24 PM(UTC)
by Dale Z 10/13/2008 3:03:59 PM(UTC)
