Dr Face
#1 Posted : Tuesday, February 12, 2013 7:42:56 PM(UTC)
Dr Face
My LG gas dryer display went out after my wife hit the start button during operation. I replaced the display control panel printed circuit board (Part # EBR36858901) but still have the same problem. There is another PCB called the main control panel (Part # EBR36858802) but both of these boards are expensive and I don't have a way of insuring that they will work. There is power to the machine as the drum light works. Any help would be appreciated. Thank you.
Dr Face
#2 Posted : Saturday, February 16, 2013 8:50:49 AM(UTC)
Dr Face
I have replaced the main control PCB (EBR36858802) and have solved the problem. Thank you for your help. A word of advice for other people with this issue...Carefully check the individual circuits on the board if you think there is a problem. After I replaced two different boards when only one needed to be replaced, I discovered a brown liquid oozing out of one of the circuits on the bad board and if I had noticed it before, I could have saved myself some time and $100.00. All one needs to do is look at them to see if they appear damaged in any way. Thanks again to this forum for your help.
