will not drain water and dishes stink motor runs washes ok solenoid does kick in checked drain at pump nothing in it can turn impeller by hand turns easy need help thanks monkey boy
ge model gsd2000j01ww will not drain solenoid does kick in when rotate control knob water and dished stink washes dishes ok checked drain at pump found nothing can turn impeller by hand turn s easy thanks monkey boy
