During a winter storm here, the electricity went on and off many times in a short period(2 min.?) Since then the only cycle we have is - high heat / 55 min. The cards must have lost most of the programming? can they be re-programmed?
Thanks in advance ..
Groups: APP Team
There are two circuit boards. How do I know which, or both, are bad?
Groups: APP Team
Hi. Replace first the one I listed above, if that doesn't help - replace the main control board Part number: W10111620
The good thing is that you may return back any parts you don't need, even installed ones. Get both controls at the same time and return the one you don't need. Post the results. Simon.
