Mobile785
#1 Posted : Monday, February 11, 2013 4:48:30 AM(UTC)
Mobile785
I hava a Kenmore upright freezer thats flaking out after being unplugged for sa period of time. When I replugged it up after a couple of hours I went down and checked on it and it was already below freezing at 5 degrees and still cooling. Went down and check on it again a little later on and it was -3.5 inside and still running. The dial was set at 5 out of 6.
Next morning I went back down to check on it and it was 59 degrees and the fan was running but no longer cooling. I tried to turn the dial back up to 6 and check on it again later but it would no longer cool. I unplugged it for a couple of hours and then plugged it back up. Same results, it cooled to below zero within a couple of hours but by the next morning it was just about 60 degrees again.
Any ideas?
Jimmy
Simon / APP Team
#2 Posted : Monday, February 11, 2013 12:46:51 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to check two thing for me, please.
First - if the compressor is running and not clicking.
Second - open the evaporator cover and check what is the frost pattern on the coils.Covered evenly, partially,blocked with snow,ice in one corner?
Post the results.
Simon.
Mobile785
#3 Posted : Monday, February 11, 2013 2:25:35 PM(UTC)
Mobile785
I think I've traced it back to the defrost timer. I tested the Defrost T-Stat and that passed and the next test was the timer and that failed. No reading at all from Common to any of the other posts. Before testing though, when I did take the back off there was frost in the front left corner of the coil but no frost throughout the rest of the coil but that was when I was getting the 60 degree reading.
Simon / APP Team
#4 Posted : Monday, February 11, 2013 3:58:00 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You may have the sealed system problem, the partial restriction in particular.
Repair of that kind of the problem will need a pro.
If the evaporator coils are not covered with frost - it's not the defrost system failure.
Simon.
Mobile785
#5 Posted : Thursday, February 14, 2013 6:35:37 AM(UTC)
Mobile785
My only question about the restriction is why would it work for 6-8 hours before it stopped working?
Simon / APP Team
#6 Posted : Thursday, February 14, 2013 1:27:38 PM(UTC)
Simon / APP Team
Groups: APP Team
The particles or the moisture are flowing inside the sealed system.Sometimes it takes awhile to clog the capillary tube.
Simon.
Mobile785
#7 Posted : Friday, February 15, 2013 12:27:20 PM(UTC)
Mobile785
Ahhh, well it sounds like I wasted $10 on a Defrost timer. I'll most likely have to scrap it as its most likely going to cost more to repair then to buy a newer one.
Thanks for your help.
Jimmy
Simon / APP Team
#8 Posted : Friday, February 15, 2013 12:50:02 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
